[GRASS-user] SQLite connection - error
Espen Isaksen espen.isaksen at gmail.com
Thu Jun 24 08:51:44 EDT 2010
Ok, so that means that grass 7 should be better at importing ogr
vector formats then right? My 100 mb file has now been running for
more than 24 hours and not done yet.
My GSHHS data was really just a test, I need to import other large
shapefiles as well. But thanks for the tip :-)
Espen
2010/6/24 Markus Metz <markus.metz.giswork at googlemail.com>:
> On Thu, Jun 24, 2010 at 10:35 AM, Espen Isaksen <espen.isaksen at gmail.com> wrote:
>> Thanks Achim and Ben for your quick answers! I never even thought
>> about that(a bit embarrassing really :-) )
>> I suppose that means I am back to the horribly slow import through
>> v.in.ogr. Practically impossible for me to import a 100 mb shapefile.
>> If anybody has suggestions for good performance, please go ahead and
>> tell me.
> You could try grass 7, see [1]
> Really big shapefiles like GADM v1 (gadm1.shp is 913 MB) will take at
> least 1 hour, though.
> Alternatively, get v.in.gshhs from grass-addons [2], get the original
> GSHHS data [3] and import those with v.in.gshhs
> Markus M
> [1] http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#Radim.27s_TODO_list
> [2] http://grass.osgeo.org/wiki/GRASS_AddOns#v.in.gshhs
> [3] ftp://ftp.soest.hawaii.edu/pwessel/gshhs/gshhs_2.0.tbz
>> 2010/6/24 Achim Kisseler <achim.kisseler at jupiter.uni-freiburg.de>:
>>> This is because SQLite is not SpatiaLite (SQLite with spatial extension).
>>> GRASS does not support SpatiaLite as far as I know.
>>> If you just want to use the Data from Spatiallite, you can export the tables
>>> as shape-files or csv and import these to GRASS.
>>> Hope it helps a bit,
>>> Achim
>>> Espen Isaksen schrieb:
>>>> Hi!
>>>> I have tried to read the documentation and the mailing list for how to
>>>> connect to a SQLite database. So far I have done this:
>>>> 1. db.connect driver=sqlite database='/home/espen/db.sqlite'
>>>> 2. Created a new vector map called test
>>>> 3. v.db.connect map=test table=GSHHS_f_L2 -o key=PK_UID
>>>> However I get this warning:
>>>> WARNING: SQLite driver: unable to parse decltype: POLYGON
>>>> WARNING: SQLite driver: column 'Geometry', SQLite type 2 is not supported
>>>> The table <GSHHS_f_L2> is now part of vector map <test> and may be deleted
>>>> or overwritten by GRASS modules
>>>> And running v.info map=test show that the layer does not have any objects
>>>>  | Layer:           test
>>>>  | Mapset:          PERMANENT
>>>>  | Location:        newLocation
>>>>  | Database:        /home/espen/Dokumenter/grassdata
>>>>  | Title:
>>>>  | Map scale:       1:1
>>>>  | Map format:      native
>>>>  | Name of creator: espen
>>>>  | Organization:
>>>>  | Source date:     Wed Jun 23 08:55:30 2010
>>>>  |   Type of Map:  vector (level: 2)
>>>>  |   Number of points:       0               Number of areas:      0
>>>>  |   Number of lines:        0               Number of islands:    0
>>>>  |   Number of boundaries:   0               Number of faces:      0
>>>>  |   Number of centroids:    0               Number of kernels:    0
>>>>  |   Map is 3D:              No
>>>>  |   Number of dblinks:      1
>>>>  |         Projection: Lat/Lon
>>>>  |               N:                 0    S:                 0
>>>>  |               E:                 0    W:                 0
>>>>  |   Digitization threshold: 0
>>>>  |   Comments:
>>>> Could anybody explain to me what the warning means, and why I cannot
>>>> access the features? The only thing i can guess is that I can only use
>>>> version 1 of SQLite? However, I am not familiar with the different
>>>> versions of SQLite.
>>>> Kind regards,
>>>> Espen Isaksen
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
