[GRASS-user] Re: debian lenny : /usr/lib/grass64/etc/prompt.sh: line 2: g.gisenv: command not found
ruffert mkm ruffert at mkm.de
Tue Jun 29 04:34:45 EDT 2010
Thanks for the help:
Maris Nartiss wrote:
> env | grep GISBASE
> It should give something like:
> GISBASE=/path/to/grass-6.4
GISBASE=/usr/lib/grass64/
contentes of /usr/bin/grass64:
# Set the GISBASE variable
export GISBASE
exec "$GISBASE/etc/Init.sh" "$@"
If in a grass shell I cd to /usr/lib/grass64/bin (which contains g.gisenv)
all is well (obviously).
If I set PATH to contain "/usr/lib/grass64/bin" no errors are reported, even
if leave the directory /usr/lib/grass64/bin.
If I set PATH to contain "/usr/lib/grass64/" the errors are reported again.
Should I set GISBASE to /usr/lib/grass64/bin in /usr/bin/grass64, or will
that make problems?
And the more general question is: how can I repair my broken install? Is an
aptitude reinstall enough to correct things?
Thanks for the help,
Ed.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/debian-lenny-usr-lib-grass64-etc-prompt-sh-line-2-g-gisenv-command-not-found-tp5230349p5234144.html
Sent from the Grass - Users mailing list archive at Nabble.com.
