[GRASS-user] Re: debian lenny : /usr/lib/grass64/etc/prompt.sh:
line 2: g.gisenv: command not found
Maris Nartiss
maris.gis at gmail.com
Tue Jun 29 05:33:56 EDT 2010
Hello,
I just unpacked that deb and tested on my Gentoo system. Everything
works just fine.
GISBASE should point to /usr/lib/grass64
You can try to reinstall, still I don't see why current install could
fail, as PATH is set by $GISBASE/etc/Init.sh around line 258.
After launching GRASS, Your $PATH should start with
"/usr/lib/grass64/bin". (echo $PATH) Are You using some strange shell?
Maris.
2010/6/29, ruffert mkm <ruffert at mkm.de>:
> Thanks for the help:
> Maris Nartiss wrote:
>> env | grep GISBASE
>> It should give something like:
>> GISBASE=/path/to/grass-6.4
> GISBASE=/usr/lib/grass64/
> contentes of /usr/bin/grass64:
> # Set the GISBASE variable
> export GISBASE
> exec "$GISBASE/etc/Init.sh" "$@"
> If in a grass shell I cd to /usr/lib/grass64/bin (which contains g.gisenv)
> all is well (obviously).
> If I set PATH to contain "/usr/lib/grass64/bin" no errors are reported, even
> if leave the directory /usr/lib/grass64/bin.
> If I set PATH to contain "/usr/lib/grass64/" the errors are reported again.
> Should I set GISBASE to /usr/lib/grass64/bin in /usr/bin/grass64, or will
> that make problems?
> And the more general question is: how can I repair my broken install? Is an
> aptitude reinstall enough to correct things?
> Thanks for the help,
> Ed.
> http://osgeo-org.1803224.n2.nabble.com/debian-lenny-usr-lib-grass64-etc-prompt-sh-line-2-g-gisenv-command-not-found-tp5230349p5234144.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
