[GRASS-user] r.fillnulls error
    maven apache
    apachemaven0 at gmail.com
    Mon Mar  1 03:35:24 EST 2010
2010/3/1 Hamish <hamish_b at yahoo.com>
> maven apache wrote:
> > When I use the r.fillnulls command to resample a map:
> > r.fillnulls input=aa output=ab tension=40 smooth=0.1
> > It show me that: taking too long to find points for
> > interpolation--please change the region to area where your
> > points are. Continuing calculations...
> > What does it mean?
> It means you should read the fabulous "NOTES" section of the r.fillnulls
> man page.  ;-)
> (the warning is harmless in this context, ignore it)
> Hamish
> ps::devs- use r.to.vect -zb in the r.fillnulls script? v.surf.rst doesn't
> need them and it could save a lot of memory etc if lidar data with many
> holes is thrown at it.
> Oh, thanks, I see it.
However what perplexing me these days is to call grass in command line model
in windows platform,forward a message:
HI:
I want to run grass in a command line model, however when I write a bat,it
works just for 6.3 version , and some command can not work for example I can
run g.version ,rather than r.fillnulls.
The grass variable bat is :
@echo off
rem *******Environment variables***********
rem Set GRASS Installation Directory Variable
set GRASSDIR=F:\anzhuang\GRASS
rem set GISBASE=D:\GrassDataBase
set GISRC=C:\Documents and Settings\Administrator\.
grassrc6
rem Set Path to utilities (libraries and bynaries) used by GRASS
set PATH=%GRASSDIR%\msys\bin;%PATH%
set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%GRASSDIR%\extrabin;%PATH%
set
PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%
set
PATH=%PATH%;%GRASSDIR%\bin;%GRASSDIR%\lib;%GRASSDIR%\scripts;%GRASSDIR%\etc;%GRASSDIR%\sqlite\lib;%GRASSDIR%\sqlite\bin;
rem Path to the proj files (notably the epsg projection list)
set GRASS_PROJSHARE=%GRASSDIR%\proj
And I write a work bat :
r.in.gdal
input=D:\data\hdf5\new\OMI-Aura_L3-OMTO3e_2009m0729_v003-2009m0731t020127.tif
output=aa location=al
g.gisenv set=LOCATION_NAME=al
g.region rast=aa
r.null map=aa setnull=-1.267e+30--1.268e+30
r.out.gdal input=ab format=GTiff
output=D:/OMI-Aura_L3-OMTO3e_2009m0729_v003-2009m0731t020127.tif
It does not work,.
I wonder why?
In fact what I am trying to do is to call grass in my web application(like
the web processing service),now I want to handle the hdf5 data,the following
is my idea:
1) use gdalinfo to get the information of the he5,(the gdal model in grass
6.3 does not support this command, the 6.4 support)
2) change the subdataset to geotiff, use gdal_translate
3) import the tiff to grass and create a new location according the tif
4) log in to the new location use g.gisenv
5) set some sepical cell data to null by using r.null....
6) Interpolation the null data using r.fillnulls.
7) export the map to geotiff.
So anyone can give some advise?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100301/80d38ab6/attachment-0001.html
