[GRASS-user] Move points to nearest feature in a different layer
    Daniel Victoria
    daniel.victoria at gmail.com
    Mon Mar  1 06:59:44 EST 2010
I've done it using v.distance. It can output the x and y coords of the
nearest feature (check upload option). So then I just created a new
point vector with the coords given by v.distance
Cheers
Daniel
2010/3/1 "António M. Rodrigues" <amrodrigues at fcsh.unl.pt>:
> Dear GRASS users,
> I'm having some problems trying to find a way to snap/move all points from
> one layer to the nearest node in another layer.
> I found that with v.distance, I can find distances to all nodes in the
> desired layer (the information is in the output window, although I haven't
> figured out yet how to manipulate this).
> Also, v.edit has a move and a snap option, although I believe the module
> expects some input like coordinates, not the name of another layer.
> So, I'm guessing that the solution will probably involve working with these
> two funcions, but I haven't figured out how
> Perhaps I'm just looking in the wrong place and there is a function in GRASS
> that performs this "snap to another layer" in one go.
> I'm sorry if this is kind of a beginner question...
> Thanks for any help.
> António
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
