[GRASS-user] ps.map issue
Hamish hamish_b at yahoo.com
Tue Mar 2 04:45:33 EST 2010
Rich wrote:
>   This is for my information
> only now as I don't need an answer right away.
>   I have a ps.map script that uses a raster map, two
> boundary vline maps,
> and a vpoints map. There are also clauses for text,
> colortable, and vlegend.
> It make for a pretty map.
>   However, if I add one more vline map (the stream
> channels), the colortable
> does not display and ghostscript complains about a problem.
> I cannot figure
> out why. I changed the sequence in which elements were
> processed and drawn, but this made no difference.
>   Has anyone seen anything like this before?
not that I know of.
does it happen if the vlines map is the only instruction given?
ie can you try to isolate it and submit a test case to the bug trac'er?
thanks
Hamish
