[GRASS-user] grass env
maven apache apachemaven0 at gmail.com
Tue Mar 2 08:22:52 EST 2010
It seems that the batch job is easy,however I still have some questions:
1) during my process the location and mapset maybe changed, can it be set in
the script file?
2) My application is to support multiple users, so each user should have a
gisrc file, can it be set before run the batch job?
2010/3/2 Markus Neteler <neteler at osgeo.org>
> On Tue, Mar 2, 2010 at 12:05 PM, maven apache <apachemaven0 at gmail.com>
> wrote:
> > Hi:
> > I have post this problem before, I want to run grass in command line
> model
> > so I can call them in java at that time,however it often cause some
> > unexpeced errors.
> > So today I change to Ubuntu, and I install grass use sudo apt-get install
> > grass.
> > Now I also want to call grass in my java code but in the Ubuntu platform,
> I
> > want to know which environment variables are needed, so I  did some
> tests.
> > First I run grass in text model in the ternimal by " grass -text",
> > and I chose the location and mapset,it works, then I use command "set >
> > /home/kk/var" to get all the environment variablse using by grass ,then I
> > open a new ternimal to get the normal env vars by " set > /home/kk/varn"
> > Then  I compare the two files and tried to find the differences. I found
> > that there are more variables in the varn rather than var (shown below):
> > GISBASE=/usr/lib/grass64
> > GISRC=/tmp/grass6-kk-9581/gisrc
> > GIS_LOCK=9581
> > GRASS_GNUPLOT='gnuplot -persist'
> > GRASS_HTML_BROWSER=x-www-browser
> > GRASS_LD_LIBRARY_PATH=/usr/lib/grass64/lib
> > GRASS_PAGER=pager
> > GRASS_PERL=/usr/bin/perl
> > GRASS_PROJSHARE=/usr/share/proj
> > GRASS_PYTHON=python
> > GRASS_SH=/bin/sh
> > GRASS_TCLSH=tclsh
> > GRASS_VERSION=6.4.0RC5
> > GRASS_WISH=wish
> > So I want to know if these vars are enough?
> I have no idea. But it is way easier to use GRASS in batch mode:
> http://grass.osgeo.org/wiki/GRASS_and_Shell#GRASS_Batch_jobs
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100302/ed7f634c/attachment.html
