[GRASS-user] grass env
Markus Neteler
neteler at osgeo.org
Tue Mar 2 08:03:04 EST 2010
On Tue, Mar 2, 2010 at 12:05 PM, maven apache <apachemaven0 at gmail.com> wrote:
> Hi:
> I have post this problem before, I want to run grass in command line model
> so I can call them in java at that time,however it often cause some
> unexpeced errors.
> So today I change to Ubuntu, and I install grass use sudo apt-get install
> grass.
> Now I also want to call grass in my java code but in the Ubuntu platform, I
> want to know which environment variables are needed, so I did some tests.
> First I run grass in text model in the ternimal by " grass -text",
> and I chose the location and mapset,it works, then I use command "set >
> /home/kk/var" to get all the environment variablse using by grass ,then I
> open a new ternimal to get the normal env vars by " set > /home/kk/varn" .
> Then I compare the two files and tried to find the differences. I found
> that there are more variables in the varn rather than var (shown below):
> GISBASE=/usr/lib/grass64
> GISRC=/tmp/grass6-kk-9581/gisrc
> GIS_LOCK=9581
> GRASS_GNUPLOT='gnuplot -persist'
> GRASS_HTML_BROWSER=x-www-browser
> GRASS_LD_LIBRARY_PATH=/usr/lib/grass64/lib
> GRASS_PAGER=pager
> GRASS_PERL=/usr/bin/perl
> GRASS_PROJSHARE=/usr/share/proj
> GRASS_PYTHON=python
> GRASS_SH=/bin/sh
> GRASS_TCLSH=tclsh
> GRASS_VERSION=6.4.0RC5
> GRASS_WISH=wish
> So I want to know if these vars are enough?
I have no idea. But it is way easier to use GRASS in batch mode:
http://grass.osgeo.org/wiki/GRASS_and_Shell#GRASS_Batch_jobs
Markus
