[GRASS-user] Custom Projection Problems
Casey Vandenberg casey.vandenberg at sjgeophysics.com
Tue Mar 2 13:05:35 EST 2010
I am trying to create a new project using a custom proj4 string. The
parameters I specify are '+proj=utm +zone=6 +ellps=clark66
+towgs84=-5,135,172'. After creating the project however, and verifying
the projection settings using *g.proj -j -f -p* I get the following info:
-PROJ_INFO-------------------------------------------------
name       : Universal Transverse Mercator
proj       : utm
ellps      : wgs84
zone       : 6
towgs84    : -5,135,172,0,0,0,0
no_defs    : defined
-PROJ_UNITS------------------------------------------------
unit       : Meter
units      : Meters
meters     : 1
+proj=utm +no_defs +zone=6 +a=6378137 +rf=298.257223563
+towgs84=-5,135,172,0,0,0,0 +to_meter=1
Why is it not maintaining the Clarke 1866 Elliposid?
Alternatively, if I specify a proj 4 string as follows: '+proj=utm
+zone=6 +datum=nad27 +towgs84=-5,135,172' and verify the created
projection using g.proj, I get the following output:
proj       : utm
datum      : nad27
ellps      : clark66
zone       : 6
no_defs    : defined
unit       : meter
units      : meters
meters     : 1
+proj=utm +no_defs +zone=6 +a=6378206.4 +rf=294.9786982
+towgs84=-22.000,157.000,176.000 +to_meter=1
Here it is maintaining the correct ellipsoid, but it does not maintain
the towgs84 datum transformation parameters.
Is this a bug or is my interpretation of creating custom projections
completely wrong?
Thanks,
Casey
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100302/df2628bb/attachment-0001.html
