[GRASS-user] run grass in linux command -- r.fillnulls errors
maven apache
apachemaven0 at gmail.com
Tue Mar 2 21:38:55 EST 2010
2010/3/3 Markus Neteler <neteler at osgeo.org>
> On Tue, Mar 2, 2010 at 2:55 PM, maven apache <apachemaven0 at gmail.com>
> wrote:
> > Hi:
> > When I run grass in command line model, the r.fillnulls can not be
> > completed, I post the input and output in the terminal , I hope some one
> can
> > check it :
> > GRASS 6.4.0RC5 (spearfish60):~/grass/GrassDataBase > g.gisenv
> please post the output of
> g.region -p
GRASS 6.4.0RC5 (spearfish60):~ > g.gisenv
GISDBASE=/home/kk/grass/GrassDataBase
LOCATION_NAME=spearfish60
MAPSET=PERMANENT
GRASS_GUI=text
GRASS 6.4.0RC5 (spearfish60):~ > g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928000
south: 4914000
west: 590000
east: 609000
nsres: 100
ewres: 100
rows: 140
cols: 190
cells: 26600
GRASS 6.4.0RC5 (spearfish60):~ > r.in.gdal
input=/home/kk/grass/data/4404.tif output=aa location=al
Location <al> created
100%
r.in.gdal complete. Raster map <aa> created.
GRASS 6.4.0RC5 (spearfish60):~ > g.mapset location=al mapset=PERMANENT
Erasing monitors...
Cleaning up temporary files...
WARNING: Your shell continues to use the history for the old mapset
You can switch the history by commands:
history -w; history -r
/home/kk/grass/GrassDataBase/al/PERMANENT/.bash_history;
HISTFILE=/home/kk/grass/GrassDataBase/al/PERMANENT/.bash_history
LOCATION_NAME=al
MAPSET=PERMANENT
GRASS_GUI=text
MONITOR=cairo7
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:15
ewres: 0:15
rows: 720
cols: 1440
cells: 1036800
> > GRASS 6.4.0RC5 (spearfish60):~/grass/GrassDataBase > r.fillnulls input=aa
> > output=abc tension=40 smooth=0.1
> > Locating and isolating NULL areas...
> > 100%
> > Number of points: 704828
> > Removing raster <MASK>
> > Using segmentation for interpolation...
> > Percent complete:
> > will require 4874896 bytes of disk space for temp files
> > Killed
> I wonder if too much RAM was used and swap exceeded?
I run linux in the vitual machine within vmware in the win platform, is it
who cause the problem?
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100303/d50cc369/attachment-0001.html
