[GRASS-user] run grass in linux command -- r.fillnulls errors
Markus Neteler neteler at osgeo.org
Tue Mar 2 14:46:58 EST 2010
On Tue, Mar 2, 2010 at 2:55 PM, maven apache <apachemaven0 at gmail.com> wrote:
> Hi:
> When I run grass in command line model, the r.fillnulls can not be
> completed, I post the input and output in the terminal , I hope some one can
> check it :
> GRASS 6.4.0RC5 (spearfish60):~/grass/GrassDataBase > g.gisenv
please post the output of
g.region -p
> GRASS 6.4.0RC5 (spearfish60):~/grass/GrassDataBase > r.fillnulls input=aa
> output=abc tension=40 smooth=0.1
> Locating and isolating NULL areas...
>  100%
> Number of points: 704828
> Removing raster <MASK>
> Using segmentation for interpolation...
> Percent complete:
> will require 4874896 bytes of disk space for temp files
> Killed
I wonder if too much RAM was used and swap exceeded?
Markus
