[GRASS-user] How to embed a grass script (for example v.db.addcol) into a Pythonscript on windows?
Sonja Jankowfsky sonja.jankowfsky at cemagref.fr
Wed Mar 3 11:46:43 EST 2010
Thanks, but the data type doesn't change that's a shell script. I still
have the same error message: (sorry, it's in french, but it says as much
as v.db.addcol is not a executable program or a bat file).
I tried as well os.system("v.db.addcol map=ditch columns='urban int'"),
but it's the same.
Sonja
'""' n'est pas reconnu en tant que commande interne
ou externe, un programme ex‚cutable ou un fichier de commandes
Martin Landa a écrit :
> Hi,
> 2010/3/3 Sonja Jankowfsky <sonja.jankowfsky at cemagref.fr>:
>> grass.run_command("v.db.addcol", map='ditch_l',  columns='urban')
> specify data column type, e.g.
> grass.run_command("v.db.addcol", map='ditch_l',  columns='urban int')
> Martin
Sonja Jankowfsky
UR Hydrologie-Hydraulique
Cemagref de Lyon
3 bis quai Chauveau CP 220
69336 Lyon Cedex 09
FRANCE
Tel : (+33)4 72 20 86 11
Fax : (+33)4 78 47 78 75
