[GRASS-user] How to embed a grass script (for example v.db.addcol) into a Pythonscript on windows?
Wed Mar 3 17:47:46 EST 2010
Sonja Jankowfsky wrote:
> Thanks, but the data type doesn't change that's a shell script. I still
> have the same error message: (sorry, it's in french, but it says as much
> as v.db.addcol is not a executable program or a bat file).
> I tried as well os.system("v.db.addcol map=ditch columns='urban int'"),
> but it's the same.
This can occur if PATH is incorrect. GRASS' "bin" directory should be
in the path, the "scripts" directory shouldn't be. There should be a
batch file named v.db.addcol.bat in the "bin" directory.
