[GRASS-user] error in opening google earth kml files in grass64
on ubuntu
Maris Nartiss
maris.gis at gmail.com
Fri Mar 5 04:26:47 EST 2010
Hello,
can You test if OGR reads Shapefile correctly?
ogrinfo -ro polygons2.shp polygons
It should print out all features and their attributes in Shapefile. If
process ends well - it's a GRASS problem, otherwise it's an GDAL/OGR
problem.
Maris.
2010/3/5, bharath s <bharath.settur at gmail.com>:
> hello,
> iam working on grass64 (ubuntu)..... My installation is correct...(no
> errors)....
> i tried to open shape files....
> but iam getting the error as shown in attach file....
> i.e unable to Error in fseek() or fread() reading object from shape file....
> please check my process of doing the import process...
> process:
> first i selected area using polygon in googleearth after that i saved as kml
> file...
> then i converted kml to shp file using online converters...
> i imported to grass by v.in.ogr if i run the error came ...
> vector file is created but it is not showing any thing...........
> please reply me .......
> thank u...
> bharath.s
