[GRASS-user] Multiple centroid coord point to one polygon
Moreno Mancosu nomero at tiscali.it
Fri Mar 5 16:14:54 EST 2010
Hi all,
I'm a three-day-old grass user, so my question can result a bit silly,
but I searched anywhere on the web, without any answer.
I have a set of 1546 centroids which refers to as many areas of a vector
map. Some of these centroids points to more than one polygon, so my
attempt to set a column in a table with these centroids miserably
fails.
I try to make something like this:
> v.db.addcol mymap col="x double precision,y  double precision"
> v.to.db mymap type=centroid option=coor col=centr_x,centr_y
When I run the v.to.db command, Grass return as many warnings as are the
areas with "doubled" centroids.
I read that I have to use the v.category command, but I really don't
know how to use it!
Any idea?
Thanks in advance,
	Moreno Mancosu
