[GRASS-user] Running Python scripts inside GRASS
Glynn Clements
glynn at gclements.plus.com
Mon Mar 8 17:38:23 EST 2010
Sonja Jankowfsky wrote:
> I uninstalled Python25 and 24 on my machine and reinstalled Python26 +
> the packages wxPython,
> PyWin32, and NumPy.
> the ftype python.file in the command line changed to Python26 now.
> However, when I try to run the python script in GRASS I still get the following error:
> File "E:\pythoninput\test_simple.py", line 2, in <module>
> import grass.script as grass
> File "C:\GRASS-4-SVN\etc\python\grass\script\__init__.py", line 1, in
> <module>
> from core import *
> File "C:\GRASS-4-SVN\etc\python\grass\script\core.py", line 30, in
> <module>
> import subprocess
> File "C:\GRASS-4-SVN\Python25\lib\subprocess.py", line 376, in <module>
So you didn't remove the one version of Python which should have been
removed, i.e. C:\GRASS-4-SVN\Python25.
You should delete this directory, and change any environment variables
which refer to it to refer to the system version of Python (e.g.
C:\Python26 or C:\Program Files\Python26) instead.
