[GRASS-user] Input raster map is outside current region
ciccpaol at libero.it ciccpaol at libero.it
Thu Mar 11 04:32:07 EST 2010
Hi everybody,
I imported a raster map in an UTM_ED50_32N location; i want to reproject it to
a target location WGS84;
once i'm in the target location i use r.proj command, what i get is:
Input Projection Parameters:  +proj=utm +no_defs +zone=32 +a=6378388 +rf=297
+towgs84=-87.000,-98.000,-121.000
Input Unit Factor: 1
Output Projection Parameters:  +proj=longlat +no_defs +a=6378137 +rf=298.
257223563 +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
How can I fix it?
I tried setting a new region in the target location ,but doesn't work.
Thanks
