[GRASS-user] Syntax error (v.distance in Python)
Glynn Clements
glynn at gclements.plus.com
Mon Mar 15 13:56:09 EDT 2010
Matthias Oswald wrote:
> I wrote a small python script including the v.distance command:
> grass.run_command("v.distance", flags='a', from=fromLayer, to=toLayer, upload='cat,dist', column='column1,column2', table=tablename)
> Running this command is resulting in a syntax error. I think it is
> because of the "from"
It is. "from" is a Python keyword (used for "from module import ...").
> but I couldn't figure out how to solve it. So, it would be great if
> someone could help me out.
Add a leading underscore, i.e.:
grass.run_command("v.distance", flags='a', _from=fromLayer, ...
make_command (and thus everything which uses it: run_command,
start_command, etc) automatically removes a leading underscore from
any option names, in order to deal with exactly this situation (see
scripts/v.what.vect/v.what.vect.py).
