[GRASS-user] Re: grass v.db.join
Gary Nobles
garynobles at yahoo.com
Tue Mar 16 09:01:21 EDT 2010
db.descibe -c returns:
ncols: 27
nrows: 811
Column 1: cat:INTEGER:11
Column 2: SquareNumb:DOUBLE PRECISION:22
Column 3: UniqueIden:DOUBLE PRECISION:22
Column 4: UniqueIdentifier:INTEGER:11
Column 5: SiteCode:CHARACTER:1
Column 6: FindLocation:INTEGER:11
Column 7: SampleNumber:TEXT:65535
Column 8: TrenchNumber:INTEGER:11
Column 9: LayerNumber:INTEGER:11
Column 10: SquareNumber:CHARACTER:1
Column 11: IDZoological:INTEGER:11
Column 12: FindSubNumber:INTEGER:11
Column 13: Class:CHARACTER:1
Column 14: Type:CHARACTER:1
Column 15: Element:CHARACTER:1
Column 16: Part:CHARACTER:1
Column 17: l_r:CHARACTER:1
Column 18: Count:INTEGER:11
Column 19: Weight:DOUBLE PRECISION:22
Column 20: Proximal:INTEGER:11
Column 21: Distal:INTEGER:11
Column 22: Age:INTEGER:11
Column 23: sex:CHARACTER:1
Column 24: Sizes:CHARACTER:1
Column 25: Association:CHARACTER:1
Column 26: Comments:CHARACTER:1
Column 27: LASTMODIFIED:TIMESTAMP :19
The original table which was joined to this one, from which I want the same
structure is:
ncols: 21
nrows: 890
Column 1: UniqueIdentifier:INTEGER:10
Column 2: TrenchNumber:INTEGER:1
Column 3: LayerNumber:INTEGER:1
Column 4: SquareNumber:CHARACTER:50
Column 5: IDZoological:INTEGER:5
Column 6: FindSubNumber:INTEGER:3
Column 7: Class:CHARACTER:10
Column 8: Type:CHARACTER:10
Column 9: Element:CHARACTER:10
Column 10: Part:CHARACTER:10
Column 11: Position:CHARACTER:10
Column 12: Count:INTEGER:4
Column 13: Weight:DOUBLE PRECISION:5
Column 14: Proximal:INTEGER:5
Column 15: Distal:INTEGER:5
Column 16: Age:INTEGER:5
Column 17: Sex:CHARACTER:10
Column 18: Sizes:CHARACTER:10
Column 19: Association:CHARACTER:30
Column 20: Comments:CHARACTER:50
Column 21: LASTMODIFIED:TIMESTAMP :19
Thank you for your help
Gary
View this message in context: http://n2.nabble.com/grass-v-db-join-tp4721541p4743397.html
Sent from the Grass - Users mailing list archive at Nabble.com.
