[GRASS-user] Environment variables for Mac OSX
William Kyngesburye
woklist at kyngchaos.com
Wed Mar 17 11:48:09 EDT 2010
Environment variables on OSX work just like on Linux.
If you need to know what a GRASS env var should be, run GRASS and check it there. But GISRC is tricky because it's temporary updated copy of ~/.grassrc6.
It sounds like you are writing scripts to run outside of a GRASS session. There has been discussion on this on the lists, check the archives. There might be something in the wiki about it.
On Mar 11, 2010, at 8:34 AM, schorschli wrote:
> Hi all,
> I wanted to start writing small python scripts for grass. Unfortunatelly I
> fail to set the environment variables right. I'm struggeling since hours to
> get them right. I found topics about environment variable in linux and
> windows, but nothing for mac:
> http://grass.osgeo.org/wiki/GRASS_and_Python
> http://grass.osgeo.org/wiki/Using_Eclipse_to_develop_GRASS_Python_programs
> Here is my last version I tried:
> GISBASE = /Applications/GRASS-6.4.app/Contents/MacOS
> LD_LIBARY_PATH = /Applications/GRASS-6.4.app/Contents/MacOS/lib
> PATH = /System/Library/Frameworks/Python.framework/Versions/2.5/Resources/
> PYTHONLIB = /System/Library/Frameworks/Python.framework/Versions/2.5
> PYTHONPATH = /Applications/GRASS-6.4.app/Contents/MacOS/etc/python
> I have no clue how to define GISRC and GRASS_SH.
> It would be great, if someone could give me some advices how they should be
> defined.
> Kind regards,
> Mat
> View this message in context: http://n2.nabble.com/Environment-variables-for-Mac-OSX-tp4716253p4716253.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
