[GRASS-user] High resolution dem
Hamish hamish_b at yahoo.com
Fri Mar 19 08:36:55 EDT 2010
> > Frank Broniewski wrote:
> >> My region is 17.000 x 13.000 cells wide (5m horiz.
> >> resolution). So my
Hamish:
> > that is getting big, but shouldn't be too bad. except
> > perhaps for v.surf.rst (and r.fillnulls which uses it).
> > hmmm... I wonder if it would speed up r.fillnulls & save
> > lots of memory if we added the no-table and no-topology -b
> > and -z flags to the r.to.vect step in it?
Markus:
> This requires that v.info reads without topology. I have
> locally backported the changed from MarkusM and modified
> r.fillnulls.
> Result: as slow/fast as before.
how about memory usage?
> A real alternative is to use v.surf.bspline rather than
> v.surf.rst which will be way faster.
I guess we should start by offering that as a flag in r.fillnulls.
Hamish
