[GRASS-user] v.to.rast multiple points per pixel
Daniel Victoria
daniel.victoria at gmail.com
Sat Mar 20 09:31:45 EDT 2010
Gary,
If you want to get a raster with the sum of the point values you will
probably have to first create a vector file where the value in each
point is the sum. Then you rasterize this vector. Just not sure how
it´s done....
Another way that might work, is export the points as ascii and use
r.in.xyz. The command was not designed for that but should work...
Good luck
Daniel
On Sat, Mar 20, 2010 at 8:28 AM, Gary Nobles <garynobles at yahoo.com> wrote:
> Hi,
> I have been trying to rasterise a point dataset, many points are exactly on
> top of each other.
> They have the attribute Count
> |Count|
> | 15 |
> | 51 |
> | 31 |
> | 12 |
> I think when I run r.to.rast it is only taking one of the count values and
> not summing the totals as when I query the data base sum('Count') I get
> different values (more in the database than the raster (r.stat))
> Is this right? How to I get around this?
> Thanks again
> Gary
> View this message in context: http://n2.nabble.com/v-to-rast-multiple-points-per-pixel-tp4768008p4768008.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
