[GRASS-user] v.to.rast multiple points per pixel
    Hamish
    hamish_b at yahoo.com
    Sat Mar 20 10:07:41 EDT 2010
Daniel Victoria wrote:
> Another way that might work, is export the points as ascii
> and use r.in.xyz. The command was not designed for that but
> should work...
actually r.in.xyz is inspired by s.cellstats for GRASS 5, and this
is exactly the sort of thing s.cellstats was designed to do. so
it is a good insight.
you can pipe directly from v.out.ascii to r.in.xyz btw.
Hamish
