[GRASS-user] Re: make command (install add on)
schorschli
matthiasoswald at hotmail.com
Mon Mar 22 05:44:01 EDT 2010
Thanks for answering.
>Are you sure about this directory?
>MODULE_TOPDIR should point to the GRASS installation directory which
>contains bin/, lib/ and other GRASS stuff.
Yes, the directory is the one containing the grass-folders (bin/, lib/ and
others).
I could solve this problem. It was not a wrong MODULE_TOPDIR path, but wrong
extensions for the makefiles.
Now I can run the make command. But this is resulting in hunderts of errors
and warning. Here is a printscreen of the first couple of lignes in the
console...
http://n2.nabble.com/file/n4776893/errors.png
http://n2.nabble.com/file/n4776893/errors.png errors.png
So maybe its better to just give it up with the addons...
View this message in context: http://n2.nabble.com/make-command-install-add-on-tp4764072p4776893.html
Sent from the Grass - Users mailing list archive at Nabble.com.
