[GRASS-user] Re: make command (install add on)
Markus Neteler
neteler at osgeo.org
Tue Mar 23 16:31:28 EDT 2010
On Mon, Mar 22, 2010 at 10:44 AM, schorschli <matthiasoswald at hotmail.com> wrote:
> Thanks for answering.
>>Are you sure about this directory?
>>MODULE_TOPDIR should point to the GRASS installation directory which
>>contains bin/, lib/ and other GRASS stuff.
> Yes, the directory is the one containing the grass-folders (bin/, lib/ and
> others).
> I could solve this problem. It was not a wrong MODULE_TOPDIR path, but wrong
> extensions for the makefiles.
> Now I can run the make command. But this is resulting in hunderts of errors
> and warning. Here is a printscreen of the first couple of lignes in the
> console...
> http://n2.nabble.com/file/n4776893/errors.png
It appears that it does not find the GRASS include files in your MacOSX
installation. As Linux user, I have no clue - maybe someone else in the list?
Markus
