[GRASS-user] Osgeo4W grass error
Daniel Victoria
daniel.victoria at gmail.com
Mon Mar 22 15:15:43 EDT 2010
Are you using Win7? I think this is a windows restriction that you
can't write to the c:\ root. This gave me a couple of headaches
also....
Cheers
Daniel
On Mon, Mar 22, 2010 at 4:09 PM, Pablo Carreira
<pablotcarreira at hotmail.com> wrote:
> Hi Milena,
> It works,
> but as reported on ticket 1022 it can't write to c:\
> (it's a windows restriction?).
> look at the tests:
> Test 1:
> v.out.ogr input=areas_recuperacao_trabalhado at geral
> dsn=c:\temp\teste.shp
> The map contains islands. To preserve them in the output map, use the -c
> flag
> Vector map <areas_recuperacao_trabalhado at geral> is 3D. Use format specific
> layer creation options (parameter 'lco') to export in 3D rather than 2D
> (default)
> 131 centroid(s) found, but not requested to be exported. Verify 'type'
> parameter.
> Exporting 564 points/lines...
> 484 features written
> 91 features without category were written
> 272 features without attributes were written
> (Mon Mar 22 15:54:17 2010) Comando terminado (1 sec)
> then I had opened the shp in qgis and the dbf in OO, everithing is ok.
> Test 2:
> dsn=c:\teste.shp
> ERROR 1: Failed to create file .shp file.
> ERROR 4: Failed to open Shapefile `c:\teste.shp'.
> flag
> (default)
> ERROR: Unable to create OGR layer
> (Mon Mar 22 16:00:05 2010) Comando terminado (0 sec)
> Regards,
> Pablo.
>> Hi Pablo,
>> good to hear!
>> Could you check if exporting a vectormap to shp works for you?
>> see: http://trac.osgeo.org/grass/ticket/1022
>> Thank you,
>> Milena
>> 2010/3/22 Pablo Carreira <pablotcarreira at hotmail.com>:
>> > I had just installed WinGRASS RC6 with the installer and it worked very
>> > well.
>> > Pablo Torres Carreira
>> Milena Nowotarska
>> http://wiki.osgeo.org/wiki/Milena_Nowotarska
>> http://quantum-gis.pl/
> ________________________________
> Fale com seus amigos do Messenger direto da Caixa de Entrada do Hotmail.
> Clique aqui
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
