[GRASS-user] Osgeo4W grass error
Milena Nowotarska do.milenki at gmail.com
Mon Mar 22 18:18:10 EDT 2010
Hi Pablo,
thank you for the tests. Did you used wxpython interface for them?
for me it still looks like this:
v.out.ogr -c input=boundary_municp at PERMANENT dsn=M:/testy/test.shp
Bad file descriptor: Files
Regards,
Milena
2010/3/22 Pablo Carreira <pablotcarreira at hotmail.com>:
> Hi Milena,
> It works,
> but as reported on ticket 1022 it can't write to c:\
> (it's a windows restriction?).
> look at the tests:
> Test 1:
> v.out.ogr input=areas_recuperacao_trabalhado at geral
> dsn=c:\temp\teste.shp
> The map contains islands. To preserve them in the output map, use the -c
> flag
> Vector map <areas_recuperacao_trabalhado at geral> is 3D. Use format specific
> layer creation options (parameter 'lco') to export in 3D rather than 2D
> (default)
> 131 centroid(s) found, but not requested to be exported. Verify 'type'
> parameter.
> Exporting 564 points/lines...
> 484 features written
> 91 features without category were written
> 272 features without attributes were written
> (Mon Mar 22 15:54:17 2010) Comando terminado (1 sec)
> then I had opened the shp in qgis and the dbf in OO, everithing is ok.
> Test 2:
> dsn=c:\teste.shp
> ERROR 1: Failed to create file .shp file.
> ERROR 4: Failed to open Shapefile `c:\teste.shp'.
> flag
> (default)
> ERROR: Unable to create OGR layer
> (Mon Mar 22 16:00:05 2010) Comando terminado (0 sec)
> Regards,
>  Pablo.
>> Hi Pablo,
>> good to hear!
>> Could you check if exporting a vectormap to shp works for you?
>> see: http://trac.osgeo.org/grass/ticket/1022
>> Thank you,
>> Milena
>> > I had just installed WinGRASS RC6 with the installer and it worked very
>> > well.
>> > Pablo Torres Carreira
>> Milena Nowotarska
>> http://wiki.osgeo.org/wiki/Milena_Nowotarska
>> http://quantum-gis.pl/
> ________________________________
> Fale com seus amigos do Messenger direto da Caixa de Entrada do Hotmail.
> Clique aqui
Milena Nowotarska
