[GRASS-user] Osgeo4W grass error
Pablo Carreira pablotcarreira at hotmail.com
Tue Mar 23 07:47:58 EDT 2010
Hi Milena,
Yes, I used wxpython WinGrass RC6 installer, not the osgeo4w version.
I've tried / and \, with -c , without -c but I couldn't reproduce that error.
Regards,
Pablo Torres Carreira
> Date: Mon, 22 Mar 2010 23:18:10 +0100
> Subject: Re: [GRASS-user] Osgeo4W grass error
> From: do.milenki at gmail.com
> To: pablotcarreira at hotmail.com
> CC: grass-user at lists.osgeo.org
> Hi Pablo,
> thank you for the tests. Did you used wxpython interface for them?
> for me it still looks like this:
> v.out.ogr -c input=boundary_municp at PERMANENT dsn=M:/testy/test.shp
> Bad file descriptor: Files
> Regards,
> Milena
> 2010/3/22 Pablo Carreira <pablotcarreira at hotmail.com>:
> > Hi Milena,
> > It works,
> > but as reported on ticket 1022 it can't write to c:\
> > (it's a windows restriction?).
> > look at the tests:
> > Test 1:
> > v.out.ogr input=areas_recuperacao_trabalhado at geral
> > dsn=c:\temp\teste.shp
> > The map contains islands. To preserve them in the output map, use the -c
> > flag
> > Vector map <areas_recuperacao_trabalhado at geral> is 3D. Use format specific
> > layer creation options (parameter 'lco') to export in 3D rather than 2D
> > (default)
> > 131 centroid(s) found, but not requested to be exported. Verify 'type'
> > parameter.
> > Exporting 564 points/lines...
> > 484 features written
> > 91 features without category were written
> > 272 features without attributes were written
> > (Mon Mar 22 15:54:17 2010) Comando terminado (1 sec)
> > then I had opened the shp in qgis and the dbf in OO, everithing is ok.
> > Test 2:
> > dsn=c:\teste.shp
> > ERROR 1: Failed to create file .shp file.
> > ERROR 4: Failed to open Shapefile `c:\teste.shp'.
> > flag
> > (default)
> > ERROR: Unable to create OGR layer
> > (Mon Mar 22 16:00:05 2010) Comando terminado (0 sec)
> > Regards,
> >  Pablo.
> >> Hi Pablo,
> >> good to hear!
> >> Could you check if exporting a vectormap to shp works for you?
> >> see: http://trac.osgeo.org/grass/ticket/1022
> >> Thank you,
> >> Milena
> >> > I had just installed WinGRASS RC6 with the installer and it worked very
> >> > well.
> >> Milena Nowotarska
> >> http://wiki.osgeo.org/wiki/Milena_Nowotarska
> >> http://quantum-gis.pl/
> > ________________________________
> > Fale com seus amigos do Messenger direto da Caixa de Entrada do Hotmail.
> > Clique aqui
> Milena Nowotarska
_________________________________________________________________
Com o Internet Explorer 8 você fica mais protegido contra ameaças da web. Saiba mais.
http://go.microsoft.com/?linkid=9707132
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100323/2ec80d8f/attachment.html
