[GRASS-user] OS MasterMap to GRASS
Leedal, David
d.t.leedal at lancaster.ac.uk
Tue Mar 23 14:22:51 EDT 2010
it works! well almost...
Thanks, I worked through each tile returned from MasterMap using v.in.ogr I now have a number of separate vector layers making up my map. No labels or colours - is this right?
Can I combine tiles to a single layer or is this not advised?
Looking forward to linking with R where I do know what I'm doing!
D
-----Original Message-----
Sent: Tue 23/03/2010 05:16
To: grass-user at lists.osgeo.org; Leedal, David
Subject: Re: [GRASS-user] OS MasterMap to GRASS
David wrote:
> This is very newbieish but I just can't find an answer out
> there. I've got Ordnance Survey MasterMap data in GML format
> downloaded from EDINA. Is there a nice way to load and
> display this data in GRASS? Or has anyone come across a
> step-by-step guide to doing this on the web?
Sure, GML is a vector format known to OGR,
http://www.gdal.org/ogr/ogr_formats.html
so you can import it with the v.in.ogr module.
see http://grass.osgeo.org/wiki/Importing_data
good luck,
Hamish
