[GRASS-user] Re: v.net.path algorithm problem
Maris Nartiss maris.gis at gmail.com
Thu Mar 25 04:28:30 EDT 2010
Your data set seems to be small. If You really think it's a bug in
v.net.path, open a ticket in Trac and attach sample data set with
commands to run. Then others developers will be able to check Your
data set and to confirm or (most likely) deny bug existence in
v.net.path.
Of-course You can g.copy that vector to another mapset and then zip it
and place on some server and then simply drop a link here. Without
seeing sample data it's impossible to tell if  it's a v.net problem,
as when I was using v.net.path half a month a go it was working just
fine.
WBR,
Maris.
