[GRASS-user] Re: v.net.path algorithm problem
schorschli matthiasoswald at hotmail.com
Thu Mar 25 04:04:24 EDT 2010
Thanks for your suggestions.
> Perhaps some nodes are missing? I have success in the past by applying
> http://grass.osgeo.org/grass64/manuals/html64_user/v.net.html
I tried v.net --> report and indeed some nodes where missing. I added those
with v.net -->nodes. Running v.net.path can still not found pathes for the
same combinations.
>Matthias - if you zoom very closely to any of the categories in the
>error report, do you see a lack of connection between those points and
>the network lines?
I couldn't find any gap in the network. The connection lines were generated
by v.net --> connect
View this message in context: http://n2.nabble.com/v-net-path-algorithm-problem-tp4789540p4796272.html
Sent from the Grass - Users mailing list archive at Nabble.com.
