[GRASS-user] translucency and svg output
Glynn Clements
glynn at gclements.plus.com
Thu Mar 25 18:10:34 EDT 2010
pete davidson wrote:
> To answer Hamish, no, I was exporting each individual layer using d.vect and
> d.out.file.
You might also want to try using the cairo driver directly, rather
than using d.out.file. E.g.:
export GRASS_CAIROFILE=out.svg
d.mon start=cairo
d.vect ...
d.vect ...
d.mon stop=cairo
> Your question gives me the idea I should try using v.out.svg
> for individual layers to help work out why Cairo dropped to raster output
> and/or to produce individual layers to stitch together later if necessary.
v.out.svg doesn't use cairo, and will never rasterise anything.
