[GRASS-user] problem cut paste commands under MSYS
John Tate john.tate at ntlworld.com
Fri Mar 26 18:19:54 EDT 2010
> if I attempt to copy and paste from a text editor to the GRASS
> command line the following results:
> "GRASS 6.4>  ^V"
I've found this also (but all the time (in Ubuntu)).
Either:
Shift+Ctrl+C or V (check keyboard shortcuts, this solution is for the shell in
Ubuntu)
or
mouse right-click and paste (a solution with DOS too).
Hope that helps. As it's the windows version there maybe some difference and
someone using that version can help.
John
