[GRASS-user] ERROR mapset <mapname> not found
Glynn Clements
glynn at gclements.plus.com
Wed Mar 31 15:07:32 EDT 2010
Achim Kisseler wrote:
> Some more details:
> I'm using grass65svn, fresh compiled on a kubuntu 64bit.
> The mapset I cannot access is one of 7. From the one I can connect to
> the others, but not the other way around.
> Could it be that the mapset is locked? If yes, where can I find out and
> how can I change that?
A mapset is locked by creating a ".gislock" file in the mapset
directory (note the leading "."). But the error which you report
doesn't sound like a locked mapset.
It would help if you specified the exact command which you run and the
exact error message (copied and pasted, not re-typed) which it
generates.
Are you sure that the directory is actually a mapset, i.e. does it
contain the WIND and VAR files? Do these files have the correct
ownership and permissions?
