[GRASS-user] GRASS 7.0 - OS X install problem
Stuart Edwards sedwards2 at cinci.rr.com
Fri May 7 11:05:13 EDT 2010
Hi -
I'm trying to install GRASS 7.0 on OS X 10.6.3 and ran into some problems:
First some errors during the make process
	GRASS GIS compilation log
Started compilation: Fri May 7 09:22:05 EDT 2010
 Errors in:
/Users/stu/grass_trunk/gui/wxpython
/Users/stu/grass_trunk/visualization/nviz
 In case of errors please change into the directory with error and run 'make'. If you get multiple errors, you need to deal with them in the order they appear in the error log. If you get an error building a library, you will also get errors from anything which uses the library.
I followed the instructions and get no errors on the first 're-make' and the following on the second:
SEsMacPro:grass_trunk stu$ cd visualization/nviz
SEsMacPro:nviz stu$ make
make -C src
gcc  -g -O2   -I/Users/stu/grass_trunk/dist.i386-apple-darwin10.3.0/include -I/Users/stu/grass_trunk/dist.i386-apple-darwin10.3.0/include  -D_FILE_OFFSET_BITS=64 -I/Library/Frameworks/Tcl.framework/Headers -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders -I/Library/Frameworks/Tcl.framework/Headers -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders -I/Users/stu/grass_trunk/dist.i386-apple-darwin10.3.0/include -I/Users/stu/grass_trunk/dist.i386-apple-darwin10.3.0/include -I/Library/Frameworks/UnixImageIO.framework/unix/include  -I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include  -DPACKAGE=\""grassmods"\"   -I/Users/stu/grass_trunk/dist.i386-apple-darwin10.3.0/include -I/Users/stu/grass_trunk/dist.i386-apple-darwin10.3.0/include -o OBJ.i386-apple-darwin10.3.0/togl.o -c togl.c
In file included from /Library/Frameworks/Tk.framework/Headers/tkMacOSX.h:34,
                 from togl.c:53:
/Library/Frameworks/Tk.framework/Headers/tkPlatDecls.h:107: error: expected ‘)’ before ‘*’ token
/Library/Frameworks/Tk.framework/Headers/tkPlatDecls.h:152: error: expected ‘)’ before ‘*’ token
/Library/Frameworks/Tk.framework/Headers/tkPlatDecls.h:153: error: expected ‘;’ before ‘GWorldPtr’
togl.c: In function ‘Togl_CreateWindow’:
togl.c:2221: warning: cast to pointer from integer of different size
togl.c:2338: warning: ‘aglSetDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:313)
togl.c: In function ‘Togl_EventProc’:
togl.c:2594: warning: ‘AGLDrawable’ is deprecated
togl.c:2596: warning: ‘aglSetDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:313)
togl.c:2610: warning: ‘aglSetDrawable’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:313)
togl.c: In function ‘Togl_LoadBitmapFont’:
togl.c:3143: warning: ‘aglUseFont’ is deprecated (declared at /System/Library/Frameworks/AGL.framework/Headers/agl.h:374)
make[1]: *** [OBJ.i386-apple-darwin10.3.0/togl.o] Error 1
make: *** [default] Error 2
make install creates the GRASS-7.0.app but on opening there is the following error:
SEsMacPro:~ stu$ '/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
cp: /Applications/GRASS-7.0.app/Contents/MacOS/docs/html/grass_icon.png: No such file or directory
Rebuilding Addon menu...
Python 2.6.4 found.
/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh: line 220: /Applications/GRASS-7.0.app/Contents/MacOS/etc/Init.sh: No such file or directory
/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh: line 220: exec: /Applications/GRASS-7.0.app/Contents/MacOS/etc/Init.sh: cannot execute: No such file or directory
logout
Seems that at some point an Init.sh file should have been created but doesn't exist.
I note that the 7.0.app is about 37 Mb and the 6.4.app weighs in at 144 Mb - does that make sense?
Thanks for any assistance --
Stu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100507/fc22d7f5/attachment.html
