[GRASS-user] r.contour generates no lines
    Markus Neteler
    neteler at osgeo.org
    Sat May  8 10:49:21 EDT 2010
On Fri, May 7, 2010 at 1:53 PM, Hanlie Pretorius
<hanlie.pretorius at gmail.com> wrote:
> Hi,
> I tried to create contours from a  DEM with the following information:
>  |   Type of Map:  raster               Number of Categories: 255
>  |   Data Type:    FCELL
>  |   Rows:         9856
>  |   Columns:      4844
>  |   Total Cells:  47742464
>  |        Projection: Transverse Mercator
>  |            N: -3704977.57894189    S: -3803537.57894189   Res:    10
>  |            E: -15589.63705055    W: -64029.63705055   Res:    10
> However, the resulting vector file contains no lines. This is the
> output of v.info:
please check if the current region (g.region -p) matches the map
or a subset.
Markus
