[GRASS-user] problems starting Grass6.3 on Windows
Vishal Mehta
vishalm1975 at gmail.com
Tue May 11 19:59:54 EDT 2010
I'm having some recent trouble getting Grass to start on Windows XP.
when i try to start Grass i get the following message:
"error setting region (Problem with g.region): child killed:unknown signal"
and then a message box with lots of errors starting with
"cant read "parts(w)": no such variable
I've tried and failed with:
- creating a new grass database directory without spaces in the path (the
default is in My Documents but it used to work before);
- unistalling and re-installing Grass
- found some reference to gis_mlock in the archives but did not understand a
word of it...
Other info:
- I have Grass 6.3.0
- Used to work until about a week ago
- Only difference since then is that i've installed QGIS , also postgis
shaepefile loader (not sure if that would cause the trouble, perhaps a
different gdal version or something??).
It would be nice to fix this so that I can use Grass commands from QGIS..
Any tips?
Thanks,
Vishal
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100511/2fcf8d58/attachment.html
