[GRASS-user] Re: r.lake - starting from shell problem
Annalisa Minelli annagrass6 at gmail.com
Wed May 12 04:58:06 EDT 2010
Many thanks Daniel,
I gave a look at that thread few days ago but I didn't found an answer..
maybe because I would like (if it's possible) not to build grass on windows
and I supposed the 6.4 version was more "stable" than 7.
But when I found that a similar problem on linux (and I know for sure
problems on linux can be solved..) I had a hope to solve the same on win
too.
However, many thanks for the hints.
I'll update you if I obtain something good.
Yours, Annalisa.
2010/5/12 LeeDaniel <Lee.Daniel.1986 at gmail.com>
> Hey there,
> Sorry I don't have an answer, but maybe it contributes to the understanding
> of the problem:
> I've also had this exact same error message when trying to run my own
> python
> scripts from shell under Windows. The scripts seem to be fine, but GRASS
> was
> unable to use them. Somebody posted what I believe might be a solution, if
> the problem's python-based, but I haven't tried it because I rewrote it as
> a
> shell script using Linux.
> Here's the thread:
> http://osgeo-org.1803224.n2.nabble.com/Problem-with-running-Python-script-in-GRASS-td5007296.html#a5007296
> -Daniel
> http://osgeo-org.1803224.n2.nabble.com/r-lake-starting-from-shell-problem-tp5035268p5040119.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100512/6d14e886/attachment.html
