[GRASS-user] dems from coordinate lists
Micha Silver
micha at arava.co.il
Thu May 13 13:47:03 EDT 2010
MS wrote:
> If I follow correctly, instead of v.to.rast, you need to interpolate a
> raster DEM from the points. v.surf.rst produces nice results, but
> there are other interpolation modules as well in the raster category.
That's the method I use also.
I start with:
v.in.ascii -z in=<ascii_file> z=3 out=vect_pts
This creates a 3D vector using the z column as the height values.
Now set the desired region:
g.region vect=vect_pts res=xxx
Choose the raster resolution that suits your needs. If the points in the
ascii file are at 25 m spacing, then you probably could interpolate at
10m-20m resolution (or better) with no problems.
Then:
v.surf.rst in=vect_pts layer=0 elev=dem ...
The layer=0 parameter indicates that you're using the 3D vector's z
value for elevation.
Micha
> Best regards,
> Mark
> On May 13, 2010, at 10:26 AM, Hanlie Pretorius
> <hanlie.pretorius at gmail.com> wrote:
>> Hi,
>> I've obtained DEMs in text files with columns X, Y and Z at 25m
>> spacing. The first three entries in the text file are:
>> X,Y,Z
>> 99550,2.9883e+06,1473.47
>> 99550,2.98828e+06,1473.57
>> 99550,2.98825e+06,1473.63
>> To me it seems the easiest way to import these is the following:
>> 1. v.in.ascii
>> 2. Set the region to the extents of new vector file and the
>> resolution to 25m.
>> 3. v.to.rast.
>> This 'works' but I get horizontal strips of no data in my raster DEM
>> at 25m spacings.
>> Also, when I look at the raster and the vector layer together, the
>> vector points are not always on the edges of the raster cells.
>> Can someone perhaps help me to fix this?
>> g.region:
>> projection: 99 (Transverse Mercator)
>> zone: 0
>> datum: ** unknown (default: WGS84) **
>> ellipsoid: wgs84
>> north: 2988300
>> south: 2959850
>> west: 74300
>> east: 99550
>> nsres: 25
>> ewres: 25
>> rows: 1138
>> cols: 1010
>> cells: 1149380
>> v.info:
>> | Layer: dem_2628cc_25m at C83
>> | Mapset: C83
>> | Location: sa_tm_19deg_E
>> | Database: C:\Hanlie\grassdata
>> | Title:
>> | Map scale: 1:1
>> | Map format: native
>> | Name of creator: Administrator
>> | Organization:
>> | Source date: Thu May 13 16:06:07 2010
>> | Type of Map: vector (level: 2)
>> | Number of points: 1151529 Number of areas: 0
>> | Number of lines: 0 Number of islands: 0
>> | Number of boundaries: 0 Number of faces: 0
>> | Number of centroids: 0 Number of kernels: 0
>> | Map is 3D: Yes
>> | Number of dblinks: 0
>> | Projection: Transverse Mercator
>> | N: 2988300 S: 2959850
>> | E: 99550 W: 74300
>> | B: 1429.79 T: 1740.2
>> | Digitization threshold: 0
>> | Comments:
>> r.info:
>> | Layer: dem_2628cc_25m at C83 Date: Thu May 13 16:15:50
>> 2010
>> | Mapset: C83 Login of Creator:
>> Administrator
>> | DataBase: C:\Hanlie\grassdata
>> | Title: Categories ( dem_2628cc_25m )
>> | Timestamp: none
>> | Type of Map: raster Number of Categories: 0
>> | Data Type: DCELL
>> | Rows: 1138
>> | Columns: 1010
>> | Total Cells: 1149380
>> | N: 2988300 S: 2959850 Res: 25
>> | E: 99550 W: 74300 Res: 25
>> | Range of data: min = 1429.850000 max = 1739.410000
>> | Data Source:
>> | Vector Map: dem_2628cc_25m at C83 in mapset C83
>> | Original scale from vector map: 1:1
>> | Data Description:
>> | generated by v.to.rast
>> | Comments:
>> | v.to.rast input="dem_2628cc_25m at C83" output="dem_2628cc_25m"
>> use="z"\
>> | type="point,line,area" layer=1 value=1 rows=4096
>> Thanks
>> Hanlie
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
