[GRASS-user] Re: grass-user Digest, Vol 49, Issue 27
MS
mseibel at gmail.com
Fri May 14 19:03:44 EDT 2010
Is projecting to NH state plane and option? Along the lines of using
something more localized.
Mark
On May 14, 2010, at 2:06 PM, Kurt Springs <ferret_bard at mac.com> wrote:
> Thanks Rich and Dylan
> I downloaded the pdf of document #1395. At the moment I am leaning
> toward Lambert Conic Conformal (1SP) since it seems to use Lat/Long
> of Natural Origin, in case I need to use a GPS. If I am reading you
> right Latitude and longitude don't even come into the equation,
> just the projection.
> I've been looking at the website http://www.dmap.co.uk/
> utmworld.htm. I was mistaken it was 18 and 19T that NH falls in.
> However, it appears to be just the western most sliver. However, if
> I don't have to figure out the conversion, so much the better.
> Kurt
> On May 14, 2010, at 12:00 PM, grass-user-request at lists.osgeo.org
> wrote:
>> Message: 2
>> Date: Fri, 14 May 2010 08:10:20 -0700
>> From: Dylan Beaudette <dylan.beaudette at gmail.com>
>> Subject: Re: [GRASS-user] Latitude/Longitude vs UTM
>> To: Rich Shepard <rshepard at appl-ecosys.com>
>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>> Message-ID:
>> <AANLkTimnbx-ED-oCXMdGTm_Pw5ngzM48CbabS98twsF4 at mail.gmail.com>
>> Content-Type: text/plain; charset=ISO-8859-1
>> On Fri, May 14, 2010 at 6:22 AM, Rich Shepard <rshepard at appl-ecosys.com
>> > wrote:
>>> On Thu, 13 May 2010, Kurt Springs wrote:
>>>> This was interesting in that it told me that r.topidx could not
>>>> be run
>>>> with latitude and longitude and I had to convert to UTM. I was
>>>> wondering
>>>> if this is the answer to the problem and I just had to convert to
>>>> UTM.
>>> Kurt,
>>> Lat/Long represents geographic coordinates, not a projection of
>>> location
>>> on a mathematial model of the earth. UTM is the Universal Transverse
>>> Mercador projection that we see on most printed (or computer
>>> displayed) maps
>>> of the earth. There is documentation within the GRASS Web site
>>> that provides
>>> a good explanation of the differences. GRASS modules work on
>>> geographic
>>> projections, not just coordinates.
>>> There is a USGS technical report from the mid-1980s that's the
>>> standard on
>>> projections. While it is becoming more rare to locatate, see if
>>> you can find
>>> a copy.
>> I think that Rich is referring to this USGS document, #1395
>> http://pubs.er.usgs.gov/usgspubs/pp/pp1395
>> Definitely worth the price if you want to become an expert in map
>> projections.
>>>> One other question. New Hampshire appears to fall within two UTM
>>>> zones
>>>> (19T and 20T) Is there a way for a maps set to contain two UTM
>>>> zones?
>> Yes. Don't use UTM. In this case use a regional projection that suits
>> your needs:
>> 1) navigation --> use a conformal projection
>> 2) area statistics --> use an equal-area projection
>> ... etc ...
>> Variations on the Albers or Lambert (conformal) conic projections
>> work
>> quite well for large regions that are wider than tall, but for such
>> as
>> small state should be just fine. We use an Albers equal-area
>> projection to house soil survey data for the lower 48 states.
>>> Interesting. NH is a tall, narrow state so one would assume it
>>> would be
>>> within a single zone. Regardless, yes there is a way to reproject
>>> locations
>>> in one zone on the other, but it's non trivial and I've not done it.
>> I wouldn't recommend it. The desirable properties of the UTM system
>> (i.e. the fairly good compromise between distortion, preservation of
>> angles, and preservation of area) only occur within a zone's
>> boundaries. The farther you move from the central meridian of the UTM
>> zone, the more distortion you will encounter-- therefore 'projecting'
>> UTM z10 data into UTM z11 is technically possible, but not a great
>> idea.
>>> Oregon is primarily in Zone 10, but the eastern edge (I don't
>>> recall the
>>> distance within the state) is in Zone 11. The available DEM and
>>> hydrologic
>>> data were reprojected from 11 to 10 by the supplying agency.
>> Hmm...
>> Dylan
>>> Rich
>>> grass-user mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100514/2c4f6778/attachment-0001.html
