[GRASS-user] negative ET values with i.evapo.senay
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Mon May 17 19:20:39 EDT 2010
Niels Thevs wrote:
> just recently, I used the evapotranspiration command i.evapo.senay in
> order to calculate ET maps from MODIS data for irrigation fields in
> Central Asia. The maps for the summer months contain a few negative
> values in the desert areas, while the spring month maps are completely
> negative. How could I correct for those values ?
Hi Niels!
It is possible that negative values "survive" within some MODIS products
(although not wanted). I think in my case (I have found some in daily surface
reflectances) and If I recall correctly used NN interpolation _or_ just MASKED
it out along with other cloudy observations of bad quality.
How did you solve this problem?
Nikos
