[GRASS-user] Importing Landsat images with different coordinates
    Firman Hadi
    jalmiburung at gmail.com
    Tue May 18 05:01:54 EDT 2010
Dear Jenny,
Yes, I am agree that will be such a huge work :D.
Actually I am not familiar with shell script but maybe I can imagine the workflow
and perhaps someone in this list can help.
I think the algorithm of such script is:
1. Put all the imageries in one folder
2. Use gdalinfo command to read coordinate system on each file (looping command)
3. Rename each file according to its coordinate system (EPSG code)
4. Use gdalwarp command to convert each file (with specific naming convention) to WGS84
I don't know this will help :D
Regards,
Firman.
On 18 May 2010, at 15:29, Jenny Turner wrote:
> Greetings
> Firman, but imagine that I have rasters in UTM for differente zones (e.g. huge countries like USA, etc). How can I produce an automatic importing tool that uses gdalwarp to project an image to WGS84 and import to GRASS?
> Thanks for your help
> Best regards,
> Jenny
> On Mon, May 17, 2010 at 11:10 PM, Firman Hadi <jalmiburung at gmail.com> wrote:
> Hi,
> As far as I know you must define the source coordinate system.
> I think it is pretty straightforward when you are using gdalwarp.
> If there are so many images, maybe you can create a shell script to run the process.
> Cheers,
> Firman Hadi
> Center for Remote Sensing - ITB
> Jl. Ganesha No. 10,
> Labtek IX-C, 3rd Floor
> Bandung - 40132
> INDONESIA
> Phone: +62-22-2530701
> Fax: +62-22-2530702
> Website : http://crs.itb.ac.id ; www.sigro.org
> Blog : http://jalmiburung.wordpress.com
> JepratJepret: http://jalmiburung.fotografer.net
