[GRASS-user] GRASS sites file
Hamish
hamish_b at yahoo.com
Wed May 19 02:50:38 EDT 2010
Luisa wrote:
> What is a GRASS sites file? How can I obtain this?
a sites file is what vector points maps were called in earlier versions
of GRASS.
grass-addons/imagery/i.pr/TODO:
This module set was developed for GRASS 5.
TODO:
- change to ANSI prototypes
- follow SUBMITTING rules
- change sites to vector
There is a "cheap" coding option which supports the old sites API while
using new vector points maps. I don't know if these modules use that
or not. The real solution is to make them use the new vector API (not
so hard, documented into the wiki somewhere?).
Hamish
