[GRASS-user] GRASS sites file
Luisa Peña luisapena1979 at gmail.com
Thu May 20 13:52:08 EDT 2010
Yes you are absolutely right. It seems to work...
Where can I find this?
"here is a "cheap" coding option which supports the old sites API while
using new vector points maps. I don't know if these modules use that
or not. The real solution is to make them use the new vector API (not
so hard, documented into the wiki somewhere?)."
Luisa
2010/5/19 Markus Metz <markus.metz.giswork at googlemail.com>
> Luisa Peña wrote:
> > Hi there
> > Instead of GRASS sites file I used a normal GRASS-vector and I got this
> > error:
> > Dev note: Adapted sites library used for vector points. (module should be
> > updated to GRASS 6 vector library)
> This is not an error, it's simply a message meant for the developer
> maintaining this module, not even a warning, you can safely proceed.
> Since you used a normal GRASS vector, the module did not abort with an
> error, right?
> > Since I'm only testing i.pr module I would like to know where can I get
> a
> > conversion script/function between Vector->Site file?
> > If this runs ok I will implement this using GRASS vector.
> > Thanks
> > Luisa
> > 2010/5/19 Luisa Peña <luisapena1979 at gmail.com>
> >> The only warning that i get is:
> >> warning: format not a string literal and no format arguments
> >> Where is that "cheap trick". Before I do any implementation i.ptr I have
> >> to understand that its classification works. So far, fraom all the
> messages
> >> that I have read, no one can use the classification...
> >> Luisa
> >>> Hamish wrote:
> >>> > Luisa wrote:
> >>> >> What is a GRASS sites file? How can I obtain this?
> >>> > a sites file is what vector points maps were called in earlier
> versions
> >>> > of GRASS.
> >>> > grass-addons/imagery/i.pr/TODO:
> >>> > This module set was developed for GRASS 5.
> >>> > TODO:
> >>> > - change to ANSI prototypes
> >>> > - follow SUBMITTING rules
> >>> > - change sites to vector
> >>> > There is a "cheap" coding option which supports the old sites API
> while
> >>> If i.pr compiles without warnings (regarding the sites API) it should
> >>> work in 6.x. Otherwise it's not much work to change it to use the new
> >>> vector API.
> >>> Markus M
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100520/54b14404/attachment.html
