[GRASS-user] GRASS sites file
    Markus Metz
    markus.metz.giswork at googlemail.com
    Fri May 21 03:01:47 EDT 2010
Luisa Peña wrote:
> Yes you are absolutely right. It seems to work...
> Where can I find this?
> "here is a "cheap" coding option which supports the old sites API while
> using new vector points maps. I don't know if these modules use that
> or not. The real solution is to make them use the new vector API (not
> so hard, documented into the wiki somewhere?)."
The old sites API is deprecated. It does not allow modules to handle
old GRASS sites, instead a regular GRASS 6 vector with points is
required for the sites API in GRASS 6. Any module still using this old
sites API works just fine in GRASS 6 with a GRASS 6 vector. The i.pr
modules still use this API and should be updated, but that does not
mean that the i.pr modules need an old GRASS sites vector, instead
i.pr.training needs a regular GRASS 6 vector with points.
In short, as far as vector input for non-interactive i.pr.training is
concerned, the module should work just fine as is in GRASS 6.
> Markus Metz:
>> Luisa Peña wrote:
>> > Hi there
>> > Instead of GRASS sites file I used a normal GRASS-vector and I got this
>> > error:
>> > Dev note: Adapted sites library used for vector points. (module should
>> > be
>> > updated to GRASS 6 vector library)
>> This is not an error, it's simply a message meant for the developer
>> maintaining this module, not even a warning, you can safely proceed.
>> Since you used a normal GRASS vector, the module did not abort with an
>> error, right?
>> > Since I'm only testing i.pr module I would like to know where can I get
>> > a
>> > conversion script/function between Vector->Site file?
>> > If this runs ok I will implement this using GRASS vector.
>> > Thanks
>> > Luisa
>> > 2010/5/19 Luisa Peña <luisapena1979 at gmail.com>
>> >> The only warning that i get is:
>> >> warning: format not a string literal and no format arguments
>> >> Where is that "cheap trick". Before I do any implementation i.ptr I
>> >> have
>> >> to understand that its classification works. So far, fraom all the
>> >> messages
>> >> that I have read, no one can use the classification...
>> >> Luisa
>> >> 2010/5/19 Markus Metz <markus.metz.giswork at googlemail.com>
>> >>> Hamish wrote:
>> >>> > Luisa wrote:
>> >>> >> What is a GRASS sites file? How can I obtain this?
>> >>> > a sites file is what vector points maps were called in earlier
>> >>> > versions
>> >>> > of GRASS.
>> >>> > grass-addons/imagery/i.pr/TODO:
>> >>> > This module set was developed for GRASS 5.
>> >>> > TODO:
>> >>> > - change to ANSI prototypes
>> >>> > - follow SUBMITTING rules
>> >>> > - change sites to vector
>> >>> > There is a "cheap" coding option which supports the old sites API
>> >>> > while
>> >>> > (not
>> >>> If i.pr compiles without warnings (regarding the sites API) it should
>> >>> work in 6.x. Otherwise it's not much work to change it to use the new
>> >>> vector API.
>> >>> Markus M
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
