[GRASS-user] r.watershed multi flow direction
M S mseibel at gmail.com
Fri May 21 08:05:28 EDT 2010
I believe that MFD in r.watershed is in versions 6.5 and up.
Mark
On Fri, May 21, 2010 at 7:27 AM, Kristian Foerster <k.foerster at tu-bs.de> wrote:
> Hi,
> I am using GRASS 6.4.0RC5+39438 (downloaded from svn server). I would like
> to obtain basins and stream segments from digital elevation data using the
> multi flow option in r.watershed as proposed in the documentation. The
> installed version of r.watershed obviously doesn't support this feature:
> Sorry, <f> is not a valid flag
> Sorry, <convergence> is not a valid parameter
> Is there another version of the program available supporting this function?
> Thank you in advance,
> best regards,
> Kristian Förster
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
