[GRASS-user] r.watershed multi flow direction
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Fri May 21 08:47:17 EDT 2010
Furthermore, in version 6.5 and up r.watershed becomes veryvery fast!
Am 21.05.2010 14:05, schrieb M S:
> I believe that MFD in r.watershed is in versions 6.5 and up.
> Mark
> On Fri, May 21, 2010 at 7:27 AM, Kristian Foerster<k.foerster at tu-bs.de> wrote:
>> Hi,
>> I am using GRASS 6.4.0RC5+39438 (downloaded from svn server). I would like
>> to obtain basins and stream segments from digital elevation data using the
>> multi flow option in r.watershed as proposed in the documentation. The
>> installed version of r.watershed obviously doesn't support this feature:
>> Sorry,<f> is not a valid flag
>> Sorry,<convergence> is not a valid parameter
>> Is there another version of the program available supporting this function?
>> Thank you in advance,
>> best regards,
>> Kristian Förster
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
