[GRASS-user] r.watershed multi flow direction
Kristian Foerster
k.foerster at tu-bs.de
Fri May 21 10:23:38 EDT 2010
Thank you all for your help. The new r.watershed version (GRASS 6.5)
works fine and it's very fast ;-)
best regards
Kristian Förster
Achim Kisseler schrieb:
> Furthermore, in version 6.5 and up r.watershed becomes veryvery fast!
> Am 21.05.2010 14:05, schrieb M S:
>> I believe that MFD in r.watershed is in versions 6.5 and up.
>> Mark
>> On Fri, May 21, 2010 at 7:27 AM, Kristian
>> Foerster<k.foerster at tu-bs.de> wrote:
>>> Hi,
>>> I am using GRASS 6.4.0RC5+39438 (downloaded from svn server). I would
>>> like
>>> to obtain basins and stream segments from digital elevation data
>>> using the
>>> multi flow option in r.watershed as proposed in the documentation. The
>>> installed version of r.watershed obviously doesn't support this feature:
>>> Sorry,<f> is not a valid flag
>>> Sorry,<convergence> is not a valid parameter
>>> Is there another version of the program available supporting this
>>> function?
>>> Thank you in advance,
>>> best regards,
>>> Kristian Förster
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
