[GRASS-user] Warnings while importing Kompsat-2 images
Hamish
hamish_b at yahoo.com
Mon May 24 13:50:38 EDT 2010
> Luis wrote:
> Hi thereI imported Kompsat-2 images using r.in.gdal and I gfot
> this warnings:rning 1: TIFFFetchNormalTag:ASCII value for
> tag"DocumentName" does not end in null byteWarning 1:
> TIFFFetchNormalTag:ASCII value for tag
> "ImageDescription" does not end in null byteWarning 1:
> TIFFFetchNormalTag:ASCII value for tag "Artist"does not end in
> null byteWarning 1: TIFFFetchNormalTag:ASCII value for tag
> "HostComputer" does not end in null byteProjection of input
> dataset and current location appear to match
> What is the origin of this? Or what can I do to avoid this?
> Kompsat-2 images are followed by an header txt. can that be
> useful?
> Because it has recognized projection, the resolution is the
> same and even nº of cols/rows.
I believe these are actually GDAL warning messages and not GRASS
ones. Will gdalinfo and/or gdal_translate work with the files?
Hamish
