[GRASS-user] Georrectification using points
Luisa Peña
luisapena1979 at gmail.com
Wed May 26 08:32:42 EDT 2010
> you can add to the POINTS file manually (create some dummy test,
> points to see the simple text file format), or maybe more easily
> use gdal_translate to add the GCPs to a geotiff then import
> that.
Uhm my question is how can I create a Points file that is added to the
group?
Regarding http://grass.osgeo.org/wiki/Georeferencing:
What is the difference between NEW WAY and EXTRA NEW WAY ? Aren't they the
same?
Luisa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100526/86d28e5f/attachment.html
